  #21 (permalink)
Old 04-30-2010, 04:22 AM
Pills's Avatar
Pills Pills is offline
Cobra Make, Engine: RAM, 5.0L with ST10 4 spd
Originally Posted by Zedn View Post
I think the Alternator earths through the mounting bracket on the engine (from memory). So as you say David, that earth strap from the block to chassis is probably the culpret. Could just be a bit of corrosion that has formed under the connection.
Zedn, interesting point. From memory, I have not seen an earth strap from the block to the chassis.I will have a good look around tommorow. I could easily make a temporary earth strap to see if this allows the charge circuit to operate corectly.
Cheers Chris.
