Old 04-30-2010, 03:16 PM
DAVID GAGNARD's Avatar
Thanks David, I appreciate it.
How about these ?
Water Pump Pulley
P/N BBFE2WP
Pulley Diameter: 6.2"
Pilot Diameter: 0.625"
Crankshaft Pulley:
P/N BBFE2CR
Crank Pulley Diameter: 5.4"
Crank Pulley Bolt Pattern: 3 Bolt
Alternator Pulley:
P/N ALTFAN
Diameter: 2.7"
Alternator Shaft Diameter: 11/16
Nope, don't use those, look again, your UNDERDRIVING your water pump by roughly 13% with these, you want to overdrive your water pump..................
You need to reverse those numbers........
David
DAVID GAGNARD
