Thread: Empty Fuel Bowl
Old 05-01-2010, 02:31 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by Jim Norris View Post
Is it critical that the level should be set while the engine is running?
One would think you can set your float level with just an electric pump feeding it, (engine off) but you'll chase your tail because the engine is not using any fuel.
You lift the float level up, dam it's too high, now you lower the float but the level doesn't go down.
It might even go up as you force the float to "sink" within the fuel. More so with glass windows.
Gary
