  #35 (permalink)
Old 05-05-2010, 07:08 AM
cbreez cbreez is offline
The B/D Manual offers no input for ride height adjustment, but it does say it should be done before an alignment...:
The car appears to have light rate springs probably because of the vehicle weight, so if the driver is a real HEAVYWEIGHT , you will have to compensate for that. Most cars are as low as possible to the point where the tires don't hit the body. It would depend on your local roads also, whether you drive through a lot of rough patches.
For what it's worth, the top of my rear tires are about level with the wheel well opening (flare) and the front has about maybe 3/4 - 1 inch clearance. Good Luck.
I weigh 220...no bottoming out for me on bumpy roads.
