Some pics would be great, but can you possably fit a rose joint as opposed to tie rod end?
Also if it needs to be a whole lot lower will a rose joint below the stub axle connection work?
If rose joint is answer you can drill out the stub axle mount to accept a standard bolt and nut?
Cruising in 5th
