  #22 (permalink)
Old 05-06-2010, 04:39 PM
Pills's Avatar
Pills Pills is offline
Cobra Make, Engine: RAM, 5.0L with ST10 4 spd
Thanks for all your help guys. Problem now sorted out.
Outwest, your advice was spot on. This is the summary of my problem(s), yes more than one fault.
It seems that a poor earth was the START of the series of events to the final outcome.
I had a verry bad motor to frame earth, the alternator bracket was painted, so again another earth failure. This led to a situation where the alternator was working overtime to charge the battery, which led to some of the diodes failing, and the rectifier was also suspect.
We now have the battery earthed to the frame, the starter is also earthed to the frame, and yes the paint removed of the mounting bracket, and the alternator has been repaired, and so far all seems good.
Cheers Chris
