Old 05-06-2010, 08:05 PM
Pills's Avatar
Pills Pills is offline
Cobra Make, Engine: RAM, 5.0L with ST10 4 spd
Just my luck. My timming always seems to be wrong Excaliber. Can you tell me, as you have a good knowledge of the rear setup, if i was to create a similar access panel, but from the Trunk side, would this allow me good access to the necessary hardware to adjust/repair the E brake.
The reason for my question, is that I have seen a similar access panel on a RAM on the uk site, where the owner then mounted an electric fuell pump on a bracket essentially over the diff. The way my trunk is set up, I have good access to this area as the fuel tank is located above the shelf in the trunk, and with the spare wheel out, there is clear access here. If i can work out how to post a picture, I will put it up for you to see, otherwise its on cobraclub.com in the RAM section with the thread heading of Fuel pump location. or to that effect.
