Old 05-07-2010, 06:16 AM
Well you can reach the drain plug easily from the back side, in case you wanted to drain, check or refill the rear end. Which I've done from underneath but it is difficult from "down under". You still can't service the brakes, bleed the brakes or adjust the e-brake linkage from the rear.
