Old 05-12-2010, 07:31 AM
strictlypersonl strictlypersonl is offline
If the bearing is running hot, it's likely that the hub spacing has been set up incorrectly.
Hub carrier adjustments
As you can see in the above link, the torque spec for the nut is 225 lbft, but that assumes that the bearing spacers are correct.
