Old 05-13-2010, 10:10 AM
madmaxx madmaxx is offline
You can paint Beige and drive it everyday with excellent power characterisitics and reliability. If you are taking advanatage of today better braking systems, tires, wheel construction, why not engine design. No doubt if you have an original Cobra stick with 427 side oiler etc. If you have anything built after 1980 consider all your options. I would have to beleive Ford should be offering something similiar from their stock. The price point is incredible.
Originally Posted by Excaliber View Post
Perhaps, but AC had always been in search of the next engine, so it shouldn't have been a big surprise. Not to mention the stunning race records that would follow and make legendary the combination of AC, Ford and Shelby.
You go to a car show or cruise in or local gathering of the hot rod club(s) and what do you see? More freakin' GM small blocks than you can shake a stick at. Yet another 350 based crate motor, their a dime a dozen and show ZERO imagination. They are the "Walmart" of hot rod engines, cheap, decent power, easy to get, a no brainer to put in, pure vanilla.
Paint it Beige...
So the new order of "hot rods" will now sport a new order of GM small block? Like we've seen for years and years already? Buy that factory built car, buy that new crate motor, write the check and
Paint it Beige... It will be the Toyota Camry of the Hot Rod world. Cheap, run's good, makes decent horse power, easy to register and will bore me to tears!! No thanks, seen enough GM small blocks to last a lifetime.
