Old 05-13-2010, 12:56 PM
DAVID GAGNARD's Avatar
Originally Posted by CobraEd View Post
The rod length subject is not a strong area for me, BUT, . . . I always underdstood that a SHORT rod produced a greater rod angle relative to the crank and produced way more torque due to the leverage. It is called "Mechanical Advantage" This is why the 347 stroker can easily produce 400 ftlbs of torque for such a small engine but should not be reved to high due to the associated piston speed. Therefore, . . . shorter rod length = more rod angle = more torque !!!! ????
This is 180 degrees off from what he wants to do. Am I missing something
I dunno, seems we are seeing/reading totally different things as what I've seen/read so far, points to just the opposite that you have stated....
the 347 stroker uses a 5.4 in long rod with a 3.4 in. long stroke giving a rod/ratio of 1.59......these motors are notorouis for side loading and wearing the sides of the cylinder bore....because of the extreme rod angle, as the piston is coming up in the bore, the rod is trying to force the piston out of the side of the block, causing faster than normal wear, generating more friction and heat,never heard/seen/read any hard data that this will make more torque,have you??? I'm familiar with the term "Mechanical Advantage", but you can also get to a point with it where you start losing advantage instead of gaining........"Diminishing Return" I think is what it is called......
for comparison, the folowing rod/ratios
331 stroker------1.66
347 stroker------1.59
351-W-----------1.71
351-W long rod--1.88
400--------------1.65
I just took delivery of my newly published book How to Build SB Ford Racing Engines where I discuss among many things rod length-to-stroke ratio. This ratio is best for racing engines at no less than 1.7:1.
and best I can figure for big blocks;
427----------1.72
460----------1.72
I'd love to see/read any published data you have come across about the short rod/extreme rod angle/more torque theory.....
I do enjoy the research almost as much as building and running engines...
David
DAVID GAGNARD
