Old 05-13-2010, 12:24 PM
Caprimaniac's Avatar
Caprimaniac Caprimaniac is offline
Cobra Make, Engine: Unfortunataly ; none
Default Spongy pedal, SS teflon lines & MC bore
I use a adjustable balance bar pedal box. It's adjusted to give maximum pressure to the front brakes or else it will lock at the rear before the front.
The pedal is a little spongy.
OK; let's say all air is out of the brake lines.
I have noe hard lines to the front calipers. SS teflon lines (AN3) directly form the MC to the calipers. Do these lines flex??? Might that cause the bad pedal?
I've also thought about going down one size from 0.725 to 0.7" MC for the front brakes. This will make the adjustability front/ rear better. This may also give me a more positive stop in the brake pedal?
Yes, brakes are quite good (much better than last year), but I'm not 100% certain that everything is OK yet. Out autocrossing yesterday was fun!
RuneS
