I run SS flex lines and my pedal is rock hard. I run .75 MC both front and back with great results. The fact that you have to have the balance bar adjusted full front to keep the rears from locking makes me wonder if the pedal is set up correctly. If it's not it could cause the spongy feeling and the lock up. I don't know your set up but if the MC are below the wheel cylinder height you would need residual valves in the lines to keep the fluid from draining out of the lines into the MC. Use a 10# valve for drum brakes and 2# valve for discs. This could also cause a spongy feeling. Good luck
