Old 05-14-2010, 06:11 PM
krausewich krausewich is offline
Cobra Make, Engine: MidStates, 351C, 4spd, 9"
Send a message via AIM to krausewich
Default Brake screens...
Hi Mike.
A two part epoxy will work well if they are a tight fit. Rivets do work well providing that you use a like metal washer on the backside of the mesh, to prevent the rivet from pulling through. As long as the body is atleast 3/32
thick, you should be safe. If the body is real thin, you can use a washer on
the backside of the body as well.
Mike.
"It's not about getting from point A to point B. It is the point"
-J. James
M. Krause
1.508.944.3368
