Old 05-14-2010, 08:45 PM
Bob In Ct's Avatar
Bob In Ct Bob In Ct is offline
Cobra Make, Engine: SPF - 351W, 944 non-turbo
Originally Posted by undy View Post
The heat rejection factor of water being 1.0 pure antifreeze has a .8 heat rejection factor . Any addition of antifreeze to water porportionately reduces the mix's heat rejection capabilities. Pump lubrication, rust inhibitors, elevated boiling points and lowered freezing points are the only advantages of a glycol/water mix.
The only advantages? If you can you should run 50/50 all year long.
Bob
