Old 05-15-2010, 05:52 AM
krausewich krausewich is offline
Cobra Make, Engine: MidStates, 351C, 4spd, 9"
Send a message via AIM to krausewich
Default mail rail specs...
HI Scuster,
Based on 'original' dims, your main rail should run 96 5/8 - 96 3/4". Same
set of drawings displayed both . I started my measure points from the
rear of the frame working forward, leaving the variable at the front diagonal
tube, where it has the least impact on the surrounding assemblies. Not to
throw a wrench in the gears, but the 3" crossmember that Nick had
mentioned will run under your oilpan location. From the rear of the frame,
the placement (on center) is as follows...
4" - 13 3/8, 33 9/16, and 89 5/8"
3" - 59 7/8"
Good luck and happy buildin'
Mike.
"It's not about getting from point A to point B. It is the point"
-J. James
M. Krause
1.508.944.3368
