Old 05-18-2010, 10:38 AM
kitcarbp's Avatar
kitcarbp kitcarbp is offline
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
Have no idea about the reg issues in CA but in todays world, you want to go E85 since its readily available (in relative terms). The lower energy density for CNG will just take just take up too much room in tanks in my opinion and the geometry for standard CNG tanks are fixed (cylinders). It just depends how many cng cylinders you can safely mount in the trunk and what range you end up with, you need to calculate this based on your available space for tanks. If you are custom designing a cobra chassis and body for CNG tank fitment thats a different story, and can be integrated nicely Im sure.
E85 would be my first choice and it will not cost you more to build a E85 fuel system compared to gasoline if you're starting from a clean sheet design approach. Even to retrofit from gasoline to E85 is not to much $. I think you can buy E85 carbs (Edelbrock ???) in the aftermarket now. I have not priced it lately, but CNG hardware would add more cost compared to a E85 fuel Carb system. You could go FI for even more money if you want.
I would mount as big of a fuel tank or fuel cell as you can fit for E85, you can custom design a stainless steel tank to fit in your trunk (32 gallon E85 capacity comes to mind) if chassis is strong enough to handle it. If you want same range on E85 as gasoline to account for the lower energy density of E85 compared to 100% gasoline, you'll want the biggest E85 tank you can fit. My 2 cents.
"...some assembly required, ages 8 and up...... well that took longer than expected......
