Old 05-18-2010, 08:06 PM
terry lee's Avatar
terry lee terry lee is offline
GEAR GRINDER CUM LAUDE
Cobra Make, Engine: SPF #1560 w/ Ford Racing [RDI/AFR/RPM] Alum. 427CI - 575HP & TKO
With an alum block, it should have steel sleeves in all the cylinders. You should be able to re-sleeve it and use the same pistons, assuming you didn't mess up the piston in that cylinder. Check with the engine builder!
I scored a wall in mine several years ago, and that is what we did. Also went to a dry sump oiling system.
TL
BOYZ and TOYZ
With every day I grow alittle older -
BUT, I'LL NEVER GROW UP!
