05-19-2010, 07:36 AM
Cobra Make, Engine: SPF#0760
Well, knowing that your fiberglass in the area is trashed, I would probably suggest using a backing ring that is threaded to match some replacement bolts in place of the normal wood screws. Or maybe glue something to the underside of the tunnel to grip the original wood screws. (Clean the grease and dirt first on the underside of the tunnel then use epoxy glue. There was a post about a bunch of superformance parts for sale...there were replacement shifter boot rings available if I recall. Use the better one on top and the other below as a backing ring.
SPFWiringDiagrams@Comcast.net
