Old 05-20-2010, 04:17 PM
Dan Case's Avatar
Dan Case Dan Case is offline
Original Shelby Owner
Originally Posted by elmariachi View Post
Hi Dan,
Thanks for this info, I do believe in part that the bowl levels on this carb were (possibly still are) a factor. The carb is back from KC and I am still tuning and tweaking so we'll see how it ends up.
Jim
Your welcome. On fellow labored with his for a long time and finally ended up in my driveway. Once I removed the small piece of rubber fuel line liner from the front needle and seat everything was fine. On a regular Holley® you can take the side plugs out a check for things like run away fuel level but with the LeMans bowls you run blind so to speak.
Dan Case
