Old 05-21-2010, 01:11 PM
PANAVIA's Avatar
PANAVIA PANAVIA is offline
Default Kirkham Gauges / Oil water - OHM Values.
On the FE TALK thread there is a note about oil pressure reading 0.
so in other business I contacted the vendor for the gauges and received the OHM values and VOLT values as pertaining to the pressure and temp gauges.
The Gauges operate on a 0.5V+ to 5.0 v+ DC band/level. so the maximum voltage you should recieve on a guage lead is +5VDC.
The wiring heading from the Oil Pressure Gauges to the senders is three strand s ( 3) , all yellow with a stripe code per wire ;
Stripe Codes;
Yellow/ Red = POWER to SENDER, should read 5.0V+
Yellow/Black = Ground. Note: gauge supplies own reference ground, and does not rely on engine block for that signal.
Yellow / Green = Return signal reference wire from sender to gauge pod.
This should read between 0.5V+ at ign on , 0 PSI and then read 4.5V+ at 100PSI.
So if you are testing and cranking you should see the voltage value go from 0.5VDC+ to say 1.5V maybe.
so 50 PSI should be about 2.3V+
Now on to water temp;
water temp is a resistance ( think of resistance or OHMS as a parasitic drain to do work.)
As measured between the poles of the temp sender by a Ohm Meter/ Multi meter.
Water temp
100F = 295 ohms
170F = 153 ohms
195F = 100 ohms
220 = 66 ohms
280F = 28ohms
The water temp is measured by unplugging the gauge from the sensor and measuring the resistance across the 2 small posts on the WT sensor.
Hope this helps.
Steve
