Thread: Broken Bolt FYI
Old 05-21-2010, 08:36 PM
scootter's Avatar
scootter scootter is offline
Cobra Make, Engine: SPF #1436 514
Shows how well I check my writing.
It is the bracket that holds the back of the differential to the frame. It is bolted to the back with two bolts then goes up on top of the frame. I have a temporary bolt in there now and hopefully changing it tomorrow. I will take some pics of the bracket. The one that was in there didn't have a long enough shoulder to go all the way through the bracket. It snapped right at the end of the threads. The new bolt has a longer shoulder to go all the way through then i can put a washer and a distorted thread lock nut on it.
Doug, do you need any other pics while I have the car up in the air?
Scott
