Old 05-22-2010, 12:08 AM
wetdog wetdog is offline
Cobra Make, Engine: classic roadster,408cu
OFM I have done loads of them (they used to use them on ground equiptment at UAL) the best trick I can pass on is to make dummy bearings out of your old ones by taking a sanding wheel to the inside of the bearing until it slides on without having to press it on .
The other thing is to make a simple tool to hold the yoke because it takes alot of torque to loosen and tighten...WD
