Old 05-22-2010, 06:29 AM
blykins blykins is offline
Originally Posted by onefastmustang View Post
It seems the only tool I don't have is a press.. Will a bench press with a 2-4" working area work or do I need a bigger one.. ??
Put the pinion in the freezer overnight. A few minutes before you need to put the bearings on, put the bearings in boiling water. Get a good glove on and push the bearing on by hand.
As for assembly, forget crush sleeves, use a solid pinion spacer. You need a good torque wrench that reads in inch-lbs to set the pinion bearing drag. You'll also need to learn how to read gear paint...if it's not right the gears will make noise.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
