Thread: Broken Bolt FYI
Old 05-22-2010, 07:35 AM
Silverback51's Avatar
Silverback51 Silverback51 is offline
The early SPF cars had an issue with the rear end housing being mounted to low in the frame. This caused the band on the inner drivers side CV boot to hit the frame and rip off.
I pulled the bracket off and had a friend plug weld the existing holes, and then I machined new ones .50 inches higher. This results in a slight tilt to the rear end housing, but it has not caused any problems to date. And I now have .25+ inches clearance between the frame and the band on the CV boot.
While I had it off, I figured I would take a picture of it in case I needed it for future reference.
John Hall
