Old 05-22-2010, 05:14 PM
Double Venom's Avatar
Double Venom Double Venom is offline
Mike a secret that a FORD ASE mechanic showed me: when you get ready to put the washers etc. back in place you will find it almost impossible to get everything to fit where it goes. Ford does this too, only I have to use a "Come A Long" type tool with two big "L's" on each end instead of hooks. Hook one of the "L's" into each end of the axle tubes. (Have the belts/cables running across the rear end from the back (9").) Once you are ready to install tighten the come A Long, you are ONLY looking to open up the rear end by a few THOUSANDTHS! You are NOT trying to bend the tube at all! It helps to have somebody cranking on the Come A Long while you or someone is sliding the rear end together. It has NEVER taken me a FULL Click on the Come A Long to work. More of a bounce, the rear end will fall into place, then release the Come A Long.
Piece of Cake
DV
(Boy oh boy is it good to get my laptop back/fixed! Cpt. Eddie I did a boo-boo! All better!)
