Thread: Turkey Pan
Old 05-23-2010, 08:08 AM
pusherfans pusherfans is offline
Originally Posted by Rick Parker View Post
I think what you will find is that the TP (Which in a perfect world should be sealed to the underside of the hood) prevents radiated heat from being absorbed by the carburetor BUT forces ALL the Intake air to be pulled through the hood scoop. Now you say that your scoop isn't sealed to the TP, then you are pulling all the HEATED air from the top of the engine compartment into the carb. You spend thousands for the trickest heads, had them ported (more$$$), spent $800 for the latest and greatest Holley and then choke it down by forcing it to swallow nothing but hot air via a very poor path. The air/fuel ratio becomes out of wack (hot air) at a give throttle position. This is why it happens when you close the hood. Same thing happens with Webers, you're pulling the air of of the upper heated layer within the engine compartment.
you make an interesting point. So are you suggesting to pull the TP and put in a big air cleaner or to seal the TP to the hood?
The interesting point for me was that it was running great with the same air filter setup, but no TP. . . . and then suddenly this happened, so I am working on the ignition. Once that's done, if there is no improvement, I'll pull the TP and see how it runs and go from there. . . .
Thank you for your input, it does make a lot of sense!
