Old 05-24-2010, 08:40 PM
elmariachi elmariachi is offline
I have managed to install and remove (for valve adjustment) my pent roofs a couple times with no leaks, for which they are notorious. I use FelPro corks and start by putting a 1/8" bead of The Right Stuff on the valve cover and then laying down the gasket, wiggling it around to make sure it spreads the bead out nice under the gasket and onto the cover lip. Then while that is drying I clean the block with lacquer thinner. I let that all dry 10-15 minutes and then I put another 1/8" bead on the head/intake surface. I then mount 'em up and just barely snug them to where the bolts start resisting. No leaks and I can easily pop them off with a small pry bar between the cover and the intake.
