Old 05-25-2010, 07:50 AM
Sam Bozzette Sam Bozzette is offline
Cobra Make, Engine: A&C , 466 Ford, 5speed Tremec
I also have a BB Ford and manual trans. and I Had issues with the supplied frame mounts. I used clamps to test the positioning of the mock up block and trans. I had to pull them quite a way to meet the frame. When I removed the bolts from the from the stock Ford rubber mounts on the mock-up block the frame mounts were to far away and the engine dropped about 1/2" to 3/4" lower than the bolt holes. I attempted to shim them from the frame, but didnt like the outcome and with the suggested position I also felt the oil pan was to low to the ground. My solution was to make my own frame mounts and position the engine where I wanted it. The only major drawback to this was that I had to position the body to ensure clearance before welding the mounts into place, but to be honest what ever mounts you use it wouldent be a bad idea to test fit the body with the engine in place and the headers on. Take a look at my build pictures.
Hope this helps, Sam
