Old 01-04-2002, 04:21 AM
Bob Putnam Bob Putnam is offline
Did the car have ignition before the ballast burned out? If not, disconnect the white wire at the starter solenoid (after replacing the ballast resistor, of course ) You can probably leave this wire off in the long term anyway. It's just to give the system a 12V shot during starting, and the Unilite usually doesn't need that.
If the car actually started, you probably just had a bad ballast resistor.
Bob Putnam
-E.R.A.-
Please address parts inquiries to eraparts@sbcglobal.net
