Originally Posted by jhv48
No wrench will fit on the coupler due to the fuel pump riding almost touching the fitting. Only a long socket with a side cutout for the nylon line will work without removing the FP.
If you're going to replace the line, can't you cut the nylon hose and use a long socket to remove the existing fitting? I think you may end up having to remove the fuel pump to install the new fitting anyway.
Here's a picture of the fitting at the block. I have an electric fuel pump, so there's no problems with access.
Doug
