Old 05-25-2010, 07:10 PM
Got the Bug's Avatar
Got the Bug Got the Bug is offline
Originally Posted by jhv48 View Post
No wrench will fit on the coupler due to the fuel pump riding almost touching the fitting. Only a long socket with a side cutout for the nylon line will work without removing the FP.
If you're going to replace the line, can't you cut the nylon hose and use a long socket to remove the existing fitting? I think you may end up having to remove the fuel pump to install the new fitting anyway.
Here's a picture of the fitting at the block. I have an electric fuel pump, so there's no problems with access.
Doug
