Old 05-27-2010, 03:07 PM
Tommy's Avatar
Tommy Tommy is offline
When you troubleshoot your problem, keep in mind that the ammeter shows how much current is flowing through it. It could be high, as was previously noted, because the alternator/voltage regulator is pushing too much current into the battery. It could also be high because something is drawing too much current (e.g., a short circuit). Most of the circuits that could draw such a load will have fuses or circuit breakers to protect them. But if the problem is in a wire or device that is not protected, you have the potential for starting a fire or melting your wiring.
Tommy
Previously owned EM Cobra
