Old 05-27-2010, 02:16 PM
bobcowan's Avatar
bobcowan bobcowan is offline
Oh, I see. I pictured it differant in my head. You're right, the center pull will eliminate that problem.
Mine was set up as a side pull. It worked pretty well. But I made a smidgen more power with a center pull. I suspect the side pull cause a little imbalance in the upper throttle ranges, because it pulled out of the corners better.
