Old 05-30-2010, 04:00 PM
Baz's Avatar
Baz Baz is offline
Originally Posted by 400TT View Post
The RTA could be satisfied if the rack had testing documentation or there is certification documentation to prove the shortening process did not result in the modified rack having less strength and reliability than the original rack. That's what would concern me and I expect that will also concern Baz now it has been pointed out.
I expect no one here uses a matching steering rack and column where the original ADR approval really means anything. Normally there are modifications made to the column shaft lengths, the angle of the column shaft and joints, the location of the rack & column mounts, non-matching rack to column, mount types used etc. Then you should also have calculations for amount of load being put through the steering assembly from tyres and suspension compared to the original donor vehicle with it's largest optional sized wheels and tyres.
Thanks Craig,
You have made some interesting and correct points and I take them on board. All I can do now is wait for a reply from RMC.
Baz
