Old 05-31-2010, 10:00 PM
tcrist tcrist is offline
Bolts right up to mine. But remember mine is a CRL not a CRII if that even matters.
You might want to pull your master and measure the bolt pattern, size of bolt, the part that protrudes into the booster (if there is one) your brake line fitting sizes, your caliper and rotor information. You might want to pick up the adjustable brake bias valve also. You will probably need it.
That would give Wilwood all of the information they need.
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
