Old 06-01-2010, 12:33 PM
FUNFER2's Avatar
FUNFER2 FUNFER2 is offline
You're the man Brent. (I'll be calling you)
Received mine on April 2nd 2010, and it has it built in.
#RM-6056
Here's some information I'll add.
When I called Ross from Quick Time, he said he sells a lot to SPF and fellow cobra owners, and since these cars are relatively low, the "non-rated SFI" bells are apx. 1.5" shorter on the bottom for ground clearance versus the "Rated SFI bells". He also said there is no real safety difference between the two. The SFI covers more or the plate and has more bolts on the bottom, and that most sanction bodies won't even check them and it's more of these being steel, not cast steel or aluminum.
I bought the non-rated bellhousing,... for clearance.
Since there's no instructions, what are all the parts that came with it ?
(I don't have it here with me to look, just saw a package)
Regards,
Kevin
