Old 06-02-2010, 11:33 AM
IndyCobra IndyCobra is offline
Cobra Make, Engine: LoneStar 427 SC, "Red Venom", 351W B/S 400 HP, TKO 600 .64 OD
Sure, what of? Note the Wilwood slave shown is a pull cylinder not a conventional push. They need a fork with the pivot point on the other side of the throwout bearing.
Well actually, you can install it either way depending upon the bellhousing. If the pivot ball was on the drivers side, I would install the cylinder pointing towards the back. Works either way.
Also, there's no frame clearance issues on the Lonestar either way. I think there is a mix of hydraulic bearings and slave cylinder set-ups. Lots of pros and cons either way. You can search the archives for the previous discussions on the topic. Since LSC went with the longer throw hydraulic cylinder, there have been fewer problems.
Randy
