Old 06-02-2010, 01:49 PM
carmine carmine is offline
Cobra Make, Engine: spf 2112 *427 stroker windsor
Do you have a slave mounting plate coming off the transmision made of aluminum, if so replace it with a 1/2 inch thick steel plate.
The aluminum tends to flex just enough under load that you lose that little bit of slave travel.
Also make sure that the slave rod is pushing in perfect line with clutch fork.
If not pushing in straight line you will lose slave travel from there as well.
