Old 06-03-2010, 03:04 PM
bobinyelm bobinyelm is offline
Cobra Make, Engine: Backdraft, 351W
Originally Posted by jhv48 View Post
So, if I get this right.
Clutch operates fine when cold but fails when good and hot?
Yep.
No visible leaks probably means one of two things.
1. Master cylinder or slave has an internal leak when the seals get good and hot allowing the hot (perhaps boiling) fluid to slip past the seals.
Yes, bypassing master seal was my first thought.
2. The fluid is boiling in the lines causing a loss in pressure. Try running with the electric fans on continuously. Does the problem persist?
Could be, but hood was open when this occurred, and car hadn't been driven that day-only idled for under 10 minutes. Another thread showed someone made new lines and routed them differently. I need to PM him to see if it cured his problem.
Drain the hydraulic fluid first and see what color it is. If dark brown/black, it probably has been burned. Change to a high temp DOT 4 fluid such as Wilwood 570. If it has boiled, time for some custom heat shields.
Color is normal (sample from master reservoir).
Fluid is DOT 4, and installed less than 10 miles and maybe 30 minutes engine-run-time ago (that's the total mileage on the Cobra since assembled). Is Wildwood DOT 4 fluid a much higher temp fluid than normal DOT 4?
Now drive it and see if the problem recurs. If so, then climb under the car (while the thing is still good and hot) and have a friend depress the clutch pedal. Observe the travel that the clutch fork makes (or doesn't). Is it the same as when dead cold? If not, then the M/C or slave are losing pressure internally. That will necessitate replacing first one then the other. Start with the one closest to the heat sources (headers). If that makes no change, then go to the other one. One or the other will prove faulty.
[color="red"]Yes, when I get it down from jack stands, I will drive it again. I no longer have a lift, so getting it up to see the fork move is time-consuming, but worthwhile.
I doubt the slave is the problem (if it's heat related) only because it likely did not get hot w/ the engine just idling under 10 minutes, especially w/ the hood open and cool air rising up past it.
And this is not ONLY a BDR problem. I've been chasing my heat devils in an SPF for the last few weeks.
A LOT of heat up under these cars! A small fan mounted behind the side grill blowing in continuously wouldn't hurt both master cylinders.
My car has the BDR heat shield, but hot air can rise past a heat shield.
Thanks-Bob
