  #21 (permalink)
Old 06-03-2010, 10:11 PM
jhv48 jhv48 is offline
It affects some, and others slide by without any problems. I think it depends on the engine and the tune of that engine. Higher performance engines tend to create more heat in the engine compartment.
I got all my heat shield material and Wilwood brake fluid from Summit Racing. They have the sleeves, and sheets of adhesive backed reflective tape and insulating tape. I have my new m/c sitting on my bench waiting to see if my heat shields and high temp fluid have solved my problem. Will know for sure tomorrrow. Supposed to be a hot day here in So. Cal so I'll go get stuck in traffic and see what happens. I do know that if I leave the radiator fans on while stuck, the problems disappear.
Good luck with yours. Solve it now, while the temps are relatively low in Texas or summers will be hell.
Jim
