Old 06-05-2010, 07:58 PM
andyl andyl is offline
Thanks for your feedback everyone, and yes any extra slop has to be bad.
Originally Posted by Ant View Post
Does this make the steering heavier, and the part from Summit must have 3 or more gears working together to keep the same direction.
I think they have slightly offset shafts and a large outside cup gear with teeth on the inside and a smaller drive gear running inside the outer gear so they both spin the same way, just the outer slower.
They will make steering heavier even disregarding friction. A 2:1 will reduce turns lock to lock by half but will make the steering twice as heavy. There is always a tradeoff. The one I'd get is the 1.5:1
Thanks again -Andy
