Old 06-06-2010, 08:30 AM
jhv48 jhv48 is offline
Well, so far so good with my heat problem. Installed the heat shields and hi temp brake fluid. And keep the fans running when stuck in traffic on a hot day.
I took the car on a mountain run in 85 degree temps and then let it sit and cook. Shifting was much better than previous.
No need to replace my master cylinder, as my clutch is releasing just fine hot or cold now.
I do think that running the fan when stopped in traffic helps keep things tolerable under the hood. Seems to help my situation.
Good luck with yours.
Jim
