Old 06-06-2010, 06:51 PM
olddog olddog is offline
1st - never owned nor built a blown engine. Read a fair amount on the subject.
You can get away with the 10:1 compression, if you have a good after cooler. If the air temp going into the intake stays down you can ovoid detonation, however you may have to run richer fuel ratio than ideal to help keep detonation under control. The higher the boost pressure, the more you will have to fight to keep detonation under control.
If your engine is 300 hp, 5 psi should get you to 400 hp and 10 psi to 500 hp, roughly.
Your going to put about $4K into a centrifugal blower and air to air after cooler. If I was going that route and 400 hp or so was enough, I wouldn't spend any other money on the intake, heads or cam.
To feed that much power, your injectors are not big enough and your mass flow sensor isn't either. Fuel lines may not be big enough. Fuel pump may not pump enough. The ECU will have to be totally re-tuned. Do you have an EEC4 or EEC5? You will likely need an expert tuner for such a set up.
Your bottom end may hold up to 400 hp pretty good, but likely will not stand up to 500 hp. If your going to put a new rotating assembly in it, you might as well go to a 331 or 347. My gut feel is that a 331 will live longer than a 347 especially if the rpms go north of 6K.
If you have to build the engine anyway, the money spent on the blower system can be put into heads, cam and induction and get you around 450 hp and still be reasonably street-able.
