Old 06-07-2010, 01:48 AM
blykins blykins is offline
Changing the heads would be the biggest jump for you right now. Even a ported E7 head probably won't flow 200 cfm. You can get an immediate 75-100 hp bump by changing to a good set of AFR heads with stud mounted roller rockers.
If you stay EFI, ditch the stock 5.0 upper/lower intakes and get a good Trick Flow intake setup, matched for the application.
With those two upgrades, you'll be very surprised.
Without upgrading to some good rods, I probably wouldn't take it any further than that.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
