Old 06-08-2010, 09:41 AM
kitcarbp's Avatar
kitcarbp kitcarbp is offline
Cobra Make, Engine: West Coast, 460 Ford Racing Crate w/ TREMEC TKO 600
Default Bending 304 Stainless 1/2" Fuel Line ?
ok folks, before I purchase some 1/2" 304 stainless fuel line I need some advice on hand formability from those that have worked with 1/2" 304 fuel line. I am making a hard line from fuel pump to the fuel tank. Total length will be about 4 feet. My plan is to use 0.028" wall thickness and buy seamless 304 tube from Graingers down the street. Is this the right grade and wall thickness to use ? Other SS in the aftermarket is 304 tube welded and drawn compared to seamless i am thinking of.
I have bent many 3/8" fuel lines and vacuum lines before in mild coated steel. I need a bend in the 1/2" stainless line by hand down to a radius of about 5" for my application. I have "spring benders" for tube bending that you slide over the tube, this works great for 3/8" lines IMHO. Will the spring benders also work for 1/2" SS 304 ? Feedback on what youve done is appreciated.
Thanks
"...some assembly required, ages 8 and up...... well that took longer than expected......
