Old 06-10-2010, 03:37 AM
undy's Avatar
undy undy is offline
Originally Posted by Excaliber View Post
...and don't forget to list the jet sizes if you remember!
That tunnel port dual quad looks tight man, (in more ways than one).
Off the build sheet...
pump nozzles: 31
boosters: 45206-1
booster pin size: 160
high speed bleed: .033
idle air bleeds: primary = 76, secondary = 36
main jets: primary = 76, secondary = 84
power valve: 4.5
power valve channel rest.: .055
emulsion and stages: .032/.028/.028
kill bleed: primary = .028, secondary = .028
idle feed restriction: primary = .033, secondary = .039
cross channel: primary = 144, secondary = 144
needle and seat: primary = 10, secondary = 110
float type: nitro
accelerator pump: 30cc
accelerator pump cam: orange
Talk about large/straight ports on the TW... You can see the top and stem of every intake valve along with the valve guides from the intake's carb pads. It's a real straight shot to the valve for the intake air/fuel charge. The intake is no taller than an Ebok RPM so it fits under the hood nicely.
Too many toys?? never!
