Old 06-10-2010, 08:19 PM
RestoCreations's Avatar
RestoCreations RestoCreations is offline
Cobra Make, Engine: Kirkham 289 FIA, 363 Stroker
-I have some paint that i use to mark the bolts. Its a great idea and thanks for the reminder.
-Quench-still planning the engine build, but i will make sure i have it.
-Starter wiring-no worries. I am using a ron francis harness and it is wired for a normal starter.
-Footbox cooling-mine has the hole, but does not have a vent. Any suggestions on where to order the components at a reasonable price
-I thought a hydraulic clutch eliminated cables.
-I will probably attempt to tackle heat management from inside the cockpit. I know it will not be as effective, but i am not sure what will look good on the exterior of the footbox in the engine compartment. Got any pictures?
Question-is an oil cooler really necessary on an FE motor with aluminum heads? It does get hot as hell here in the summer time and the humidity is ridiculous.
Thanks
