06-10-2010, 08:34 PM
NH
Check the angles jive on both ends. AN and pipe are different (37 and 45 deg). You can also see from the wear pattern between if it's seating properly across the flare rather than just a narrow ring. They can handle a pretty good torque on steel and stainless fittings.
