  #25 (permalink)
Old 06-12-2010, 10:53 AM
twobjshelbys's Avatar
twobjshelbys twobjshelbys is offline
Originally Posted by vector1 View Post
your v/e table looks pretty messed up from 3400+.
the a/f base map is pretty rich also and the spark advance is pretty conservative at the lower rpm and cruising.
look at the 427 chevy sb 48# injector prom ram 544 hp setup for comparison if you want something close.
if you're datalogging you should be able to come up with a better v/e table and smooth it.
i think i would find somebody else to tune it or do some learning.
when your v/e table jumps around like in your table from 3400+ i don't think it is going to run well. it needs to be smooth.
Standard rules may not apply. This is a faux 8-stack.
I don't have the base tune you mentioned. Can you email it back to me?
